rodeknop
Feb 07, 2016Aspirant
Parental Control Apple Mac WNR200v2
Hi, I've installed and configured LPC and it looks dead simple. I've set the level to high. My ipad is blocking porn sites, but my apple mac OSX is not. DNS servers are configured correct in the ...
rodeknop
No. No.
DexterJB
Feb 07, 2016NETGEAR Moderator
Hi @rodeknop,
Please try manually setting the filtering level to High for the MAC computer. You ca do this through the NETGEAR Genie app. You can download the latest version for your device using the link below.
http://netgear.com/home/discover/apps/genie.aspx
Once you have the app installed, you can follow these steps:
1. Open the app.
2. Select Parental Controls and make sure you are logged in and it is Enabled.
3. Select Network Map and login if prompted.
4. Select the MAC computer on the the Network Map.
5. Select Modify.
6. Adjust the Parental Controls Filtering to High or your preferred level and select Apply.
Dexter
Community Team
