sapphirestorm's avatar
Jan 05, 2016
Parental control not working
Hi I have been using OpenDNS only as Parental controls in Netgear Genie app have never worked. I would prefer to use Netgear genie so i have removed my network from the OpenDNS and I am trying to ge...
  • DexterJB's avatar
    DexterJB
    Feb 12, 2017
    Hi Hebby,
    Those options are the different operating modes of the router and each can be used depending on the setup of your network. If you do not have another router setup then the router mode should be the correct option.
    Dexter
    Community Team
