sapphirestorm
Jan 05, 2016Follower
Parental control not working
Hi I have been using OpenDNS only as Parental controls in Netgear Genie app have never worked. I would prefer to use Netgear genie so i have removed my network from the OpenDNS and I am trying to ge...
AndyWC
Nov 27, 2016Initiate
Turn off AP Mode. OpenDNS filtering does not work with AP Mode turned on. Go to router administration, select Advanced Tab, then Advanced Setup. Go to Wireless AP, and uncheck Enable AP Mode. The router will reboot and then the Parental Controls will work fine.
- HebbyFeb 07, 2017Aspirant
Yes thank you .. that worked for me!! finally!!
Just interested in asking.. I have the choice of unticking AP mode and selecting either router, Bridge or repeating mode... which should it be? I chose router mode and seems to work, ie it is now filtering websites, but not sure what the diff modes mean
- swevMar 29, 2017Initiate
Cant get the Parental Controls to work. tried everything here even AP mode off. Not sure what is going on. Any step by step setup info I should look at?
