sapphirestorm
Jan 05, 2016Follower
Parental control not working
Hi I have been using OpenDNS only as Parental controls in Netgear Genie app have never worked. I would prefer to use Netgear genie so i have removed my network from the OpenDNS and I am trying to ge...
jaymepechan
Jan 07, 2017Aspirant
I have been trying to get parental controls to actually do something and like others here it just doesn't do anything. I have set the default security to High and made sure on several devices to set it to Default so it would use that High setting. Yet, on all devices I have attached, I can still get to pretty common porn sites. I even put the domain in the into the blacklist but I can still access it from any device. Here is my firmware version.
Just to answer one of the common questions here. I did check the DNS entries and they are set correctly with the 208.etc.
Hardware Version R6250
| Firmware Version | V1.0.4.6_10.1.12 |
- DexterJBJan 09, 2017NETGEAR Moderator
Hi jaymepechan,
1. It may take a while for the settings to sync with the OpenDNS servers.
2. If the issue persists, make sure that the devices do not have a static DNS set to them.
Dexter
Community Team
- jaymepechanJan 09, 2017Aspirant
They all get their DNS from the router and gets set to the routers IP (192.168.1.1 in my case). I did set it to high and high for my computer and waiting for a while and it worked briefly. Of course, I don't want it set to high on my machine so I set it to medium and now it doesn't work again. I set it back to high thinking that is the only setting that works but that setting isn't working either anymore.
Currently I have it set to moderate as that is what I eventually want it at. My computer is set to Default level. I have had it set this way since my last message, which I believe was a couple days ago, yet I can still get to pornhub.com without a problem. Presumably that site should be blocked with these settings but they aren't.
- jaymepechanJan 10, 2017Aspirant
Ok, I just tried it again and all of a sudden it started working at default settings. Hopefully it stays working. I had it on high for my ipad individually and it still wasn't working but when I set it to default (medium), it started working. On my laptop where it was working, I set it to High and then it wasn't working at all anymore. It even stopped blocking medium level stuff.
