sapphirestorm
Jan 05, 2016Follower
Parental control not working
Hi I have been using OpenDNS only as Parental controls in Netgear Genie app have never worked. I would prefer to use Netgear genie so i have removed my network from the OpenDNS and I am trying to ge...
DexterJB
Jan 09, 2017NETGEAR Moderator
Hi jaymepechan,
1. It may take a while for the settings to sync with the OpenDNS servers.
2. If the issue persists, make sure that the devices do not have a static DNS set to them.
Dexter
Community Team
jaymepechan
Jan 09, 2017Aspirant
They all get their DNS from the router and gets set to the routers IP (192.168.1.1 in my case). I did set it to high and high for my computer and waiting for a while and it worked briefly. Of course, I don't want it set to high on my machine so I set it to medium and now it doesn't work again. I set it back to high thinking that is the only setting that works but that setting isn't working either anymore.
Currently I have it set to moderate as that is what I eventually want it at. My computer is set to Default level. I have had it set this way since my last message, which I believe was a couple days ago, yet I can still get to pornhub.com without a problem. Presumably that site should be blocked with these settings but they aren't.
- jaymepechanJan 10, 2017Aspirant
Ok, I just tried it again and all of a sudden it started working at default settings. Hopefully it stays working. I had it on high for my ipad individually and it still wasn't working but when I set it to default (medium), it started working. On my laptop where it was working, I set it to High and then it wasn't working at all anymore. It even stopped blocking medium level stuff.
I've confirmed that it is now working as long as the device is set to default level in the Network Map. That wasn't working before so that is an improvement. If I set anything other than Default Level in the network map, it turns off blocking completely.
- DexterJBJan 11, 2017NETGEAR Moderator
Hi jaymepechan,
Thank you for providing an update and confirmation. We will look into this.
Dexter
Community Team
