sapphirestorm
Jan 05, 2016Follower
Parental control not working
Hi I have been using OpenDNS only as Parental controls in Netgear Genie app have never worked. I would prefer to use Netgear genie so i have removed my network from the OpenDNS and I am trying to ge...
AndyWC
Nov 27, 2016Initiate
Turn off AP Mode. OpenDNS filtering does not work with AP Mode turned on. Go to router administration, select Advanced Tab, then Advanced Setup. Go to Wireless AP, and uncheck Enable AP Mode. The router will reboot and then the Parental Controls will work fine.
Hebby
Feb 07, 2017Aspirant
Yes thank you .. that worked for me!! finally!!
