sapphirestorm
Jan 05, 2016Follower
Parental control not working
Hi I have been using OpenDNS only as Parental controls in Netgear Genie app have never worked. I would prefer to use Netgear genie so i have removed my network from the OpenDNS and I am trying to ge...
AndyWC
Nov 27, 2016Initiate
Turn off AP Mode. OpenDNS filtering does not work with AP Mode turned on. Go to router administration, select Advanced Tab, then Advanced Setup. Go to Wireless AP, and uncheck Enable AP Mode. The router will reboot and then the Parental Controls will work fine.
swev
Mar 29, 2017Initiate
Cant get the Parental Controls to work. tried everything here even AP mode off. Not sure what is going on. Any step by step setup info I should look at?
