Brian-Olney-MD
Dec 31, 2015Aspirant
Parental Controls not working - Need Help
I recently purchased a AC1750 NetGear router... I'm having a problem with parental controls. Initially I had a problem downloading and installing the Genie program, because I'm running Windows 10 on...
DexterJB
Jan 02, 2016NETGEAR Moderator
Hi Brian-Olney-MD,
1. Are you also able to do the same with the other devices in the network?
2. Please check the DNS values on the router UI and make sure they are set to 208.67.222.222 and 208.67.220.220.
3. Please make sure that the Parental Controls feature is enabled on the Parental Controls status page on the NETGEAR Genie program.
Dexter
Community Team
