Capster13
May 13, 2017Guide
Parental Controls won't enable due to Bypass login
When I attempt to turn on the parental controls in the netgear genie it allows me to enable parental controls no problem. I then go to the network map to change the individual devices parental control filtering level and it says "Bypass Login". If I try to change it from anything else it says "Bypass login is active on this device, please log out bypass first."
I don't have a bypass account logged into anything. When I first started getting this error I hadn't even created a bypass login. It happens regardless of the device (I even tried it on a brand new phone with nothing installed or anything done other than connecting to the WIFI). I need to put filters for my kids devices but can't because of this.
I am still experiencing the issue. I reset the router and still had the problem. I actually completely reconfigured the router from scratch. I do not know how to disable the bypass account on the individual devices. One of them is literally a brand new iphone that does not have any apps on it so how could a bypass login even be on it?
