evr
Nov 06, 2016Aspirant
Parental Controls
Hi, I am using the browser verstion of Netgear Genie and I can log in fine. However it does not have the Parental Control. I have install the Netgear Genie App on my Power Mac and I see the Parenta...
DexterJB
Nov 07, 2016NETGEAR Moderator
Hi evr,
The logins for Parental Controls are different from the logins for the router UI (default - username: admin, password: password). You will have to sign up for an OpenDNS account through the NETGEAR Genie app. You may find the link below helpful.
http://kb.netgear.com/app/answers/detail/a_id/25687
Dexter
Community Team
- evrNov 07, 2016Aspirant
Hi Dexter JB,
So when I click on the Parental Controls is takes me to a window with the title:
"Checking router firmware
We're making sure you have firmware that supports Live Parental Controls"
and then within that window there is a smaller window that sais:
"Router Login
Please enter the username and password you use to manage you NETGEAR router..."
Can you help me figure out the "Router Login" , where I might find that and or reset it?
Best,
Enrique
- DexterJBNov 08, 2016NETGEAR Moderator
Hi evr,
You can check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/20026
Dexter
Community Team
- evrNov 08, 2016Aspirant
Thank you. I have done this, and have gone to the Netgear Genie and clicked on the Parental Controls, then when I enter the User: admin and then my new pass it still does not let me get into the process. The screen looks like it is thinking but then just stops. Any thoughts?
- powderzogDec 15, 2016Aspirant
Hi,
I am trying to setup parental controls via genie and not having any luck. I'm very frustrated.
I have an open dns account.
I have set the dns to:
208.67.222.222
208.67.220.220per the open dns support tech
After logging into the genie app and clicking parental controls it always displays:
We're making sure you have firmware that supports Live Parental Controls.
You don't appear to be connected to the internet. Please connect to the Internet through your NETGEAR router and try again.Under the internet tab and the home tab it says connected to internet.
I have updated the firmware V2.01.14.
Not sure what to do.
Please help.
Thank you
- DexterJBDec 20, 2016NETGEAR Moderator
Hi powderzog,
1. What is the model number of your router?
2. Try setting up Parental Controls without setting a static DNS.
3. Please try setting up a new OpenDNS account through the NETGEAR Genie app.
4. Have you tried using another device (Android, iOS, another computer) to setup Parental Controls?
Dexter
Community Team
- DexterJBDec 25, 2016NETGEAR Moderator
Hi powderzog,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- engr_jafferJan 01, 2017Aspirant
Hi,
I have the similar problem of not been able to activate Parental Control through NETGEAR GENIE.
I'm getting the error logging into OpenDNS account from NetGear Genie, “There was an error signing in, please make sure you’re connected to the Internet and try again.” I have tried several times, even I logged in through opendns.com and then used Genie App but could not sign through it while I remianed sign in to their website. I have NetGear C3700 – WiFi Cable Modem Router
I even opened up the ticket with OpenDNS and they recommended to contact Netgear support.
Please suggest what to do to activate Parental Control Settings.
Thanks,
Syed
