evr
Nov 06, 2016Aspirant
Parental Controls
Hi, I am using the browser verstion of Netgear Genie and I can log in fine. However it does not have the Parental Control. I have install the Netgear Genie App on my Power Mac and I see the Parenta...
DexterJB
Nov 07, 2016NETGEAR Moderator
Hi evr,
The logins for Parental Controls are different from the logins for the router UI (default - username: admin, password: password). You will have to sign up for an OpenDNS account through the NETGEAR Genie app. You may find the link below helpful.
http://kb.netgear.com/app/answers/detail/a_id/25687
Dexter
Community Team
evr
Nov 07, 2016Aspirant
Hi Dexter JB,
So when I click on the Parental Controls is takes me to a window with the title:
"Checking router firmware
We're making sure you have firmware that supports Live Parental Controls"
and then within that window there is a smaller window that sais:
"Router Login
Please enter the username and password you use to manage you NETGEAR router..."
Can you help me figure out the "Router Login" , where I might find that and or reset it?
Best,
Enrique
- DexterJBNov 08, 2016NETGEAR Moderator
Hi evr,
You can check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/20026
Dexter
Community Team
- evrNov 08, 2016Aspirant
Thank you. I have done this, and have gone to the Netgear Genie and clicked on the Parental Controls, then when I enter the User: admin and then my new pass it still does not let me get into the process. The screen looks like it is thinking but then just stops. Any thoughts?
