evr
Nov 06, 2016Aspirant
Parental Controls
Hi, I am using the browser verstion of Netgear Genie and I can log in fine. However it does not have the Parental Control. I have install the Netgear Genie App on my Power Mac and I see the Parenta...
evr
Nov 07, 2016Aspirant
Hi Dexter JB,
So when I click on the Parental Controls is takes me to a window with the title:
"Checking router firmware
We're making sure you have firmware that supports Live Parental Controls"
and then within that window there is a smaller window that sais:
"Router Login
Please enter the username and password you use to manage you NETGEAR router..."
Can you help me figure out the "Router Login" , where I might find that and or reset it?
Best,
Enrique
DexterJB
Nov 08, 2016NETGEAR Moderator
Hi evr,
You can check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/20026
Dexter
Community Team
- evrNov 08, 2016Aspirant
Thank you. I have done this, and have gone to the Netgear Genie and clicked on the Parental Controls, then when I enter the User: admin and then my new pass it still does not let me get into the process. The screen looks like it is thinking but then just stops. Any thoughts?
- DexterJBNov 09, 2016NETGEAR Moderator
Hi evr,
1. Have you tried using another device (Android, iOS, another computer)?
2. Have you tried resetting the device?
Dexter
Community Team
- evrNov 09, 2016Aspirant
Hi, I have tried to log in from my iPhone wth the Netgear Genie app, but no luck being able to even sign in there.
I have restarted the device both manually and through the web based Genie version, have also turned in on and off manually.
What do you mean by "resetting the device" and is that the same as restarting or is it something diference. If so can you advise what to do?
Thanks!
