evr
Nov 07, 2016Aspirant
Parental Controls
Hi, I am using the browser verstion of Netgear Genie and I can log in fine. However it does not have the Parental Control. I have install the Netgear Genie App on my Power Mac and I see the Parenta...
evr
Nov 09, 2016Aspirant
Thank you. I have done this, and have gone to the Netgear Genie and clicked on the Parental Controls, then when I enter the User: admin and then my new pass it still does not let me get into the process. The screen looks like it is thinking but then just stops. Any thoughts?
DexterJB
Nov 10, 2016NETGEAR Moderator
Hi evr,
1. Have you tried using another device (Android, iOS, another computer)?
2. Have you tried resetting the device?
Dexter
Community Team
- evrNov 10, 2016Aspirant
Hi, I have tried to log in from my iPhone wth the Netgear Genie app, but no luck being able to even sign in there.
I have restarted the device both manually and through the web based Genie version, have also turned in on and off manually.
What do you mean by "resetting the device" and is that the same as restarting or is it something diference. If so can you advise what to do?
Thanks!
- DexterJBNov 10, 2016NETGEAR Moderator
Hi evr,
You can check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
- DexterJBNov 13, 2016NETGEAR Moderator
Hi evr,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- evrNov 14, 2016Aspirant
Hi,
So I have done the factory reset.
The only thing I changed after doingthe factory reset is changing the name of the Wifi Name (SSID) and passphrase back to what I had them. I then log out, and log back in with the user name and pass that are the default. I can log in fine, both on the browser and on the Genie app on my macbook. But when I go to the Genie and try to log into the parental controls with the defaul user name and pass it does not work, I just keep getting the log in screen over and over again.
I also tried on my iPhone but no luck there either. Not sure what is going on. Should we get on the phone to work this out?
Thanks,
Enrique
