evr
Nov 06, 2016Aspirant
Parental Controls
Hi, I am using the browser verstion of Netgear Genie and I can log in fine. However it does not have the Parental Control. I have install the Netgear Genie App on my Power Mac and I see the Parenta...
DexterJB
Nov 07, 2016NETGEAR Moderator
Hi evr,
The logins for Parental Controls are different from the logins for the router UI (default - username: admin, password: password). You will have to sign up for an OpenDNS account through the NETGEAR Genie app. You may find the link below helpful.
http://kb.netgear.com/app/answers/detail/a_id/25687
Dexter
Community Team
powderzog
Dec 15, 2016Aspirant
Hi,
I am trying to setup parental controls via genie and not having any luck. I'm very frustrated.
I have an open dns account.
I have set the dns to:
208.67.222.222
208.67.220.220
per the open dns support tech
After logging into the genie app and clicking parental controls it always displays:
Checking router firmware
We're making sure you have firmware that supports Live Parental Controls.
You don't appear to be connected to the internet. Please connect to the Internet through your NETGEAR router and try again.
Under the internet tab and the home tab it says connected to internet.
I have updated the firmware V2.01.14.
Not sure what to do.
Please help.
Thank you
- DexterJBDec 20, 2016NETGEAR Moderator
Hi powderzog,
1. What is the model number of your router?
2. Try setting up Parental Controls without setting a static DNS.
3. Please try setting up a new OpenDNS account through the NETGEAR Genie app.
4. Have you tried using another device (Android, iOS, another computer) to setup Parental Controls?
Dexter
Community Team
- DexterJBDec 25, 2016NETGEAR Moderator
Hi powderzog,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- engr_jafferJan 01, 2017Aspirant
Hi,
I have the similar problem of not been able to activate Parental Control through NETGEAR GENIE.
I'm getting the error logging into OpenDNS account from NetGear Genie, “There was an error signing in, please make sure you’re connected to the Internet and try again.” I have tried several times, even I logged in through opendns.com and then used Genie App but could not sign through it while I remianed sign in to their website. I have NetGear C3700 – WiFi Cable Modem Router
I even opened up the ticket with OpenDNS and they recommended to contact Netgear support.
Please suggest what to do to activate Parental Control Settings.
Thanks,
Syed
- DexterJBJan 02, 2017NETGEAR Moderator
Hi engr_jaffer,
1. What is the firmware version of the your device?
2. What version of NETGEAR Genie do you have installed?
3. Have you tried using another device (Android, iOS, another computer)?
4. Have you tried uninstalling and re-installing the app/program?
Dexter
Community Team
