evr
Nov 06, 2016Aspirant
Parental Controls
Hi, I am using the browser verstion of Netgear Genie and I can log in fine. However it does not have the Parental Control. I have install the Netgear Genie App on my Power Mac and I see the Parenta...
powderzog
Dec 15, 2016Aspirant
Hi,
I am trying to setup parental controls via genie and not having any luck. I'm very frustrated.
I have an open dns account.
I have set the dns to:
208.67.222.222
208.67.220.220
per the open dns support tech
After logging into the genie app and clicking parental controls it always displays:
Checking router firmware
We're making sure you have firmware that supports Live Parental Controls.
You don't appear to be connected to the internet. Please connect to the Internet through your NETGEAR router and try again.
Under the internet tab and the home tab it says connected to internet.
I have updated the firmware V2.01.14.
Not sure what to do.
Please help.
Thank you
DexterJB
Dec 20, 2016NETGEAR Moderator
Hi powderzog,
1. What is the model number of your router?
2. Try setting up Parental Controls without setting a static DNS.
3. Please try setting up a new OpenDNS account through the NETGEAR Genie app.
4. Have you tried using another device (Android, iOS, another computer) to setup Parental Controls?
Dexter
Community Team
