evr
Nov 06, 2016Aspirant
Parental Controls
Hi, I am using the browser verstion of Netgear Genie and I can log in fine. However it does not have the Parental Control. I have install the Netgear Genie App on my Power Mac and I see the Parenta...
gintguru
Feb 12, 2017Aspirant
I am using an iMac late 2009 3GHz with 8 GB ram and a R6400 Netgear router connected to a 5268AC gateway. When I start parent controls from NetGear Genie it looks for the router to verify firmware but never seems to find it. It is always spinning on "Identifying Router." I have updated the firmware, reset the router, downloaded genie, deleted and downloaded again. I have shut down the entire system and brought back up with my 5268AC gateway, my R6400, and then my computer. I have tried just a wired connection to the R6400 router, just a wireless connection, and both being enabled. I have verified that the 5268AC Gateway wifi is disabled and the only connection is the ethernet cable. Any additional suggestions via direct email or on this thread would be great.
- DexterJBFeb 16, 2017NETGEAR Moderator
Hi gintguru,
Is the R6400 configured in AP mode or router mode? It should be configured in router mode.
Dexter
Community Team
- gintguruFeb 18, 2017Aspirant
The 6400 is configured in router mode. The firmware is up to date and Genie can confirm that. I am still getting the screen below when trying to access parent controls
