israelisraeli
May 07, 2016Aspirant
Passive FTP configitation (VEGN 2610)
I'm trying to set up an FTP server located at a NAS on my LAN. Iv'e set port forwording for the data chanel and the passive command chanel (passive range) but it seems that there's still a problem w...
TheEther
May 07, 2016Guru
Did you set up a rule to forward port 21?
- israelisraeliMay 07, 2016Aspirant
yes, with netgear's pre-made setting (which are simply TCP 20-21). you can the screenoshots in the original post
- TheEtherMay 07, 2016Guru
If your public IP really public? Does it start with 192.168.x.x, 172.16.x.x, 10.x.x.x or 100.x.x.x?
