Mikemilleriu
Apr 04, 2018Follower
Pause internet blocked all internet
Last night I paused internet on one device using the Netgear Genie app on my phone. It completely blocked all internet to all devices, including the phone I did it on. Since it will not connect to ...
- Apr 10, 2018
Hi Mikemilleriu,
Welcome to the community!
Yes, resetting the router will reverse that as well as clear all your settings. Instead, you can try accessing the router UI and disable the Access Control feature. Here is the link to access the router UI and go to Advanced > Security > Access Control.
Dexter
Community Team
DexterJB
Apr 18, 2018NETGEAR Moderator
Hi Mikemilleriu,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
