MickLion1
Apr 20, 2020Aspirant
Pause/Resume Disabled
Hello guys, With the app for my router works just fine before with functional device manager, but now it’s not working. The area where the switch between (pause/resume) has been grayed out and I ca...
MickLion1
Apr 23, 2020Aspirant
Hello Christian,
I have deleted my app and reinstalled it. Along with checking that I am connected to the internet with no new update available. The device manager pause/disabled is still grayed out (not allowing me to change to pause/disabled). During the beginning when I set it from the first time, everything worked (about like 5 months). Somehow it’s not working now.
Christian_R
Apr 24, 2020NETGEAR Employee Retired
Hello MickLion1,
May you try performing a factory reset on your router by holding down the reset button for 15+ seconds. After doing so, please run through the setup assistant again using the Nighthawk app. Can you also provide me with the model number of your router and the current firmware version it's on.
Thanks,
Christian
- michaelkenwardApr 24, 2020Guru - Experienced User
Christian_R wrote:
Hello MickLion1,
Thanks,
Christian
It might also help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?There are good reasons for also asking for that information.
- MickLion1Apr 28, 2020AspirantThank you for waiting for moment, the model number is R7000 and it’s on version V1.09.88.
- Christian_RApr 29, 2020NETGEAR Employee Retired
Hi MickLion1,
It appears your device is not on the latest firmware version. May you update to the latest firmware as I've included the file and release notes in the link below.
https://kb.netgear.com/000061805/R7000-Firmware-Version-1-0-11-100
Christian
- MickLion1Apr 30, 2020AspirantI can’t seem to install the latest update as it claim to say that they’re no new update available.
