Retired_Member
Aug 09, 2021Please allow users to clear/reset the SPEEDTEST history in the APP
Hi Is there an option currently to refresh the bulit in SPEEDTEST history? or a way to clear it? Thanks
- Retired_MemberAug 11, 2021
Looks like its a waiting game for the nighthawk application developers to add it in a future release (most likely not a priorty) since the app has been out for a while - so its seems the orignal question on clearing the SPEEDTEST log history ins't there for iOS or Andriod.
Thanks Again
Aug 10, 2021Guru - Experienced User
Does removing the app then re-installing it clear the history?
- michaelkenwardAug 10, 2021Guru - Experienced User
iOS or Android?
Android has Clear Data and Clear Cache options in App settings..
- Retired_MemberAug 10, 2021
Thanks for the replies.
FURRYe38 - If I delete the app do I loose all the current custom settings? - I would prefer an option in the app itself to allow history clearing.
michaelkenward - It should be an setting for iOS (using) and Andriod within the app.
Which brings me to another question related to notiifcations, its turned on but if a new device joins the network; I am not receive any push notifications to acknowledge a new device is connected.
Thanks in advance
That's a bit off-track on speed tests.
If you are using iOS, which isn't clear to me, I have no idea about "push notifications". Maybe it is to do with Armor, or something else I don't use.
I have no idea what "push notifications" are when it comes to the mobile app. I associate notifications with the desktop genie.
