milop
Aug 03, 2022Aspirant
Port Forwading
Suggestion for the app: Add the ability to configure port forwarding.
milop
Aug 04, 2022Aspirant
I looked for a suggestion section and missed it. I’ll post this over there.
But I’ll first say that by removing “Remote Management” from the web GUI it’s harder to enable port forwarding if the person has authorized a single IP to administer port forwarding and that person is moving around to different locations. No longer can the IP be set to the new location before going there.
Thanks for your reply.
michaelkenward
Aug 08, 2022Guru - Experienced User
I think this was a security thing.
People drop in here from time to time and moan about things like Netgear's failure to demand https for local access. (Madness, I know.) That and other perceived, and sometimes real, security loopholes have led Netgear to remove various much loved features.
Then there are things like parental controls where Netgear's third party partner, OpenDNS, pulled the plug. In some cases, there are ways around the issue that you can use if you don't use Netgear as the go between.
NOTICE: Live Parental Control Service based on Ope... - NETGEAR Communities
There may also be subscription options that you can pay for.
