Pangear's avatar
Pangear
Powerline Adapters
How many pairs of XAVB1601 adapers can be installed on one home electrical circuit, where each pair is point to point link ?
Why cannot be more downloaded power utility: netgear.com/app/products/model/a-ice/19339 ?
  • Hello Schumaku,
    You have been very inaccurately dealing with definitions about various layers. How encryption can be related to layer L2 ?
    Data Presentation and Encryption is related always to layer L6.
    Yes, I agree that all PL devices are connected to a shared media - copper electrical circuit (L0).
    My intention is just to have 3 pairs of PL devices sitting on same shared media where each pair will have own unique encrypted
    password. Perhaps, I will turn on as well as a support of QoS if I feel my applications will get a certain improvement with that.
  • michaelkenward's avatar
    michaelkenward
    Not sure that I understand the question. Point-to-point link?
    The usual arrangement is to connect one (host) plug to the router and then add as many remote (guest) plugs as you need.
    Some models seem to throw a hissy fit when you add a sixth guest plug.
    The XAVB1601 is an ancient (2012) 200 Mbps system, now replaced by 500 then 1000 and finally (so far) 2000 Mbps plugs.
    • Pangear's avatar
      Pangear
      Thanks for response but you have not answered my question.
      First of all let's clarify topology of connections or layout scheme. You mentioned "star" topology where a master PL device talks to a number
      of remote PL devices. I am interested in 3 PL device pairs where each pair establishes topology: single poin-to-point link, however all 6 PL devices are on one electrical circuit. Will these XAVB1601 devices work without interefering between these three data links?
      Regards
      • schumaku's avatar
        schumaku
        All PL share the same L0/L1 network, where L2 (MAC) and L3 (e.g. IP) is run on. There is neither a "master" not a point-to-point relation. Each PL does see any other PL device on the same electrical wire(s). The PL with the same name are able to communicate.
