vurt72
Oct 30, 2021Aspirant
Prevent iphone from 5GHz
Is there a way i can prevent my iphone from connecting to 5GHz? I want 5GHz exlusively for my Oculus Quest 2. The only way i've figured out how to even connect to 5GHz with the Quest 2 is to make su...
- Oct 31, 2021
You have the R7800?
If so, you can simply disable smart connect and name the ssid's different.
Then you can choose which network to connect to.
You should be able to run the occulus and the iphone on the 5ghz without issues though.
Oct 31, 2021Guru - Experienced User
You have the R7800?
vurt72
Oct 31, 2021Aspirant
yes, thanks. that's what i came up with eventually. i used the same name for both which led to problems.
