Retired_Member
Sep 16, 2019Problems with Ready Cloud
I have a external HDD 3.0 connected to my NightHawk router. Everything works fine between router and HDD. My problem: I installed the ReadyCloud app desktop client onto my Win10 laptop. I signe...
Retired_Member
Sep 16, 2019I found another problem with ReadyCloud.
My HDD is 1TB brand new but ReadyCloud reports it as 196.91mb and it's already full! lol
I guess using network storage through Netgear router is not going to work for me.
- DexterJBSep 16, 2019NETGEAR Moderator
Hi Retired_Member, welcome to the community! I have sent you a message. Please check your inbox.
Dexter
- Retired_MemberSep 20, 2019
DexterJB wrote:Hi Retired_Member, welcome to the community! I have sent you a message. Please check your inbox.
Dexter
I've been talking to
Matt
Expert ID: 8313
Netgear Level 2 SupportI can no longer send response back to him because there is a problem with Netgear website. When I send a reply I get this error message "Error: Something went wrong! Please try again"This is the last message that Matt wrote to me: "I did encounter an issue accessing ReadyCloud remotely using the desktop APP. Do you have the "VPN disconnected" error as well?"My response: I do not get a VPN discconected error message. I do not get any error message.Mine says: Connected (VPN) then it displays the root folder.I cannot access anything beyond the root folder. I cannot backup or download anything.- DexterJBSep 25, 2019NETGEAR Moderator
Hi Retired_Member, I followed up with the support team.
Dexter
- Retired_MemberSep 18, 2019
I fixed the problem with ReadyCloud not detecting the 1TB of storage space.
I connected the HDD to my Win10 PC and did a default format on it and then reconnected it back to the router. The only weird thing that it did was that it created two root folders and after about 10min of trying to delete one of the root folders, I was successful. So this part is now fixed.
Still not able to use ReadyCloud client app on Win10.
- michaelkenwardSep 19, 2019Guru - Experienced User
What happens when you try?
It broke here months ago.
- Retired_MemberSep 19, 2019
michaelkenward wrote:What happens when you try?
The client will connect to the router displaying the connected HDD but that's all it does.
