Retired_Member
Sep 16, 2019Problems with Ready Cloud
I have a external HDD 3.0 connected to my NightHawk router. Everything works fine between router and HDD. My problem: I installed the ReadyCloud app desktop client onto my Win10 laptop. I signe...
Retired_Member
Sep 16, 2019I found another problem with ReadyCloud.
My HDD is 1TB brand new but ReadyCloud reports it as 196.91mb and it's already full! lol
I guess using network storage through Netgear router is not going to work for me.
Retired_Member
Sep 18, 2019I fixed the problem with ReadyCloud not detecting the 1TB of storage space.
I connected the HDD to my Win10 PC and did a default format on it and then reconnected it back to the router. The only weird thing that it did was that it created two root folders and after about 10min of trying to delete one of the root folders, I was successful. So this part is now fixed.
Still not able to use ReadyCloud client app on Win10.
- michaelkenwardSep 19, 2019Guru - Experienced User
What happens when you try?
It broke here months ago.
- Retired_MemberSep 19, 2019
michaelkenward wrote:What happens when you try?
The client will connect to the router displaying the connected HDD but that's all it does.
- michaelkenwardSep 20, 2019Guru - Experienced User
It came back to life when I updated to the latest Windows app. ReadyCloudSetup 1.19.1301.569.
Mine was out of date and was so broken that it could not even look for a new version.
