SRH86
Aug 31, 2018Aspirant
QR Code for WiFi Network
I am unable to connect my genie app with my wifi on my iphone. I have opened up the wifi tab on the app and filled out appropiate headings , i was unsure what to do with the QR scan and looked it up on line and followed step 1-3 but when it came to step 4 it said the following " your wireless settings will appear along with the QR code at the bottom" then step 5 Scan the code from your mobile device to connect to your wifi.
not sure how i am meant to scan my iphone QR code when it is on my iphone does not make sense -can someone please help. Please note i also have downloaded app onto my computer this is connecting fine.
The QR code an be used to share the wireless configuration to some friends or visitors, the feature to load a wireless config from a QR code is not often implemented, it's not available by default neither on iOS nor on Android.
- SRH86AspirantHi
Thanks fir the info but I am not quite sure how this helps me with my situation , my goal is to connect my genie app with my wifi again- schumakuGuru - Experienced User
Genie App is not intended to assist with the initial connection of the mobile device to the WiFi/router - this has to be done using the means in place by the mobile OS maker.
