SRH86
Aug 31, 2018Aspirant
QR Code for WiFi Network
I am unable to connect my genie app with my wifi on my iphone. I have opened up the wifi tab on the app and filled out appropiate headings , i was unsure what to do with the QR scan and looked it up...
SRH86
Sep 01, 2018Aspirant
Hi
Yes thanks for that and I understand what you are saying but my iOS is connected to the wifi but the genie app won’t connect , when I go into my app - wifi - name - security - channel and fill in appropriate details , I still have the problem where it saids at the base of the page to scan QR code to connect which I am unsure how to do thIs , I keep getting a pop up say “ this action failed , try again “
schumaku
Sep 01, 2018Guru - Experienced User
SRH86 wrote:
... my iOS is connected to the wifi but the genie app won’t connect , when I go into my app - wifi - name - security - channel and fill in appropriate details ,
Again, this is not to connect the Genie App to the router - much more this is the place where you can change the WIFi Name, Network Key (misleadingly named password), the router AP security, and select the channel to be used.
However, at this point I would guess the mobile is connected, the Genie App is authenticated and can talk to the router - otherwise this conrol would not become accessible.
Again, most mobile devices don't offer the ability to scan this QR code to register another wireless network.
Beyond of some 3rd party Apps, you might be able to use the Genie App on another mobile device, select QR Scanner - this should allow to read and set the wireless config accordingly, permitting to connect the other device to the router WiFi.
