Jedimindtrick
Jun 18, 2016Aspirant
R4500 Parental Controls Not Blocking - Help My Kids Are Exposed
HELP PLEASE. Just unpacked my brand new NetGear N900 R4500 FW V1.0.0.4_1.0.3. Purchased from Amazon last week, Works great, but can't get parental controls to work. NetGenie and Genie App, both i...
DexterJB
Jun 19, 2016NETGEAR Moderator
Hi Jedimindtrick,
1. What version of NETGEAR Genie do you have installed?
2. What is the firmware version of the router?
3. What are the DNS values that are indicated in the router UI?
4. Are all devices affected (not getting filtered)?
5. Have you tried other filtering levels (medium, low, custom)?
6. Have you tried changing the filtering level using a different device (smartphone, tablet, another computer)?
Dexter
Community Team
Jedimindtrick
Jun 20, 2016Aspirant
Hi Dexter,
Thanks for quick reply. This is what I did and it worked.
1. Disable Parental Control in the Genie App and Genie Web Access
2. Rebooted the modem and the NetGear Router
3. Attached LAN Cable to Router from Laptop
4. Accessed Router Through Genie Web Dashboard
5. Enabled Parental Control at Moderate
All good now! Whew!!
Lesson learned, don't set parental control through Genie App.
Jedimindtrick
- DexterJBJun 22, 2016NETGEAR Moderator
