Blueeyedgirl369
Jun 12, 2019Follower
R6020
I just purchased this router and I’m trying to figure out the app. Its telling me to log in with the admin password and i am using the password found on the router and it is NOT working. Also I’m wond...
michaelkenward
Jun 12, 2019Guru - Experienced User
Login to what? The browser graphical user interface (GUI) or the wifi?
They have different passwords.
Also I’m wondering if i can use TWO routers ? We like to play video games and our internet sucks and no other companies come to our area so I’m trying to work around the laggy-ness.
Hard to unravel what is going on there. Two routers on one network is not a good idea.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
If you are talking about using two different internet suppliers, then that is a whole new can of worms.
