Sanashoks1
May 02, 2020Initiate
R6080 Ac1000 nightwalk app not showing connected device list after app firmware update
I update the Nightwalk firmware update today, after that it’s not showing any connected devices to manage. I did some troubleshoot as per existing post, like reset router, reinstall app. Nothings work...
Christian_R
May 06, 2020NETGEAR Employee Retired
Hello Sanashoks1,
Our engineering team is aware of a possible issue with attached devices feature not working properly on the Nighthawk app and they are currently investigating. We recommend using the web browser to manager your devices for now.
Christian
LRAinAK
Aug 07, 2022Aspirant
zero relevance for me. i'm new here, and am not sure how, but I was mistakenly on the wrong article at some point. I don't use nighthawk, I only use a browser. also, your handle says you are retired...how do you know what is happening internally at Netgear? Thanks for the reply.
- michaelkenwardAug 08, 2022Guru - Experienced User
"Retired" means that they are no longer members of this "Community".
Look closely at all of the messages before yours and you will see that they appeared more than two years ago.
If you didn't answer to the message before yours, heaven only knows why your message appeared here.
If you are seeking help for some sort of issue, then start a NEW conversation ion the appropriate section. See above:
