mmiii
Jun 15, 2019Follower
R6120 Access Point setup and Nighthawk app
I configured my R6120 as an access point and would like to access it with the Nighthawk app. The Wifi 2.4 / 5 is great but the Nighthawk app can not connect. In the web interface of the R6120 I can n...
michaelkenward
Jun 16, 2019Guru - Experienced User
This explains what you lose by going into AP mode:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
To access an AP device you need to work out what IP address it has acquired from your router. Then you can point a browser at that IP address.
schumaku
Jun 20, 2019Guru - Experienced User
michaelkenward wrote:This explains what you lose by going into AP mode:
Yes, this does however not explain anything ref. the local or remote Nighthawk App usage - which is both currently not available in Access Point mode. Have requested to add this to the KB entry (by using the [No] and file some feedback text).
