Dragonlim's avatar
Jul 06, 2017
R6120 Security Menu Missing Access Control
Just bought R6120 yesterday. Want to setup MAC Access Control List, unfortunately cannot find it in Security Menu. Hope that it will be available in the next upgrade. Fya, Thanks !
  • Dragonlim's avatar
    Dragonlim
    Jul 25, 2017
    Hi All,
    I just upgrade to the new firmware V1.0.0.28.
    Good News !
    Access Control is available and working fine !
    Hope that it helps other with the same issue.
    Thanks.
    Best regards
    Dragon Lim
