Dragonlim
Jul 06, 2017Guide
R6120 Security Menu Missing Access Control
Just bought R6120 yesterday. Want to setup MAC Access Control List, unfortunately cannot find it in Security Menu. Hope that it will be available in the next upgrade. Fya, Thanks !
- Jul 25, 2017
Hi All,
I just upgrade to the new firmware V1.0.0.28.
Good News !
Access Control is available and working fine !
Hope that it helps other with the same issue.
Thanks.
Best regards
Dragon Lim
michaelkenward
Jul 07, 2017Guru - Experienced User
Does that mean that page 39 of the manual is misleading?
R6120 | Product | Support | NETGEAR
"You can use access control to block or allow access of devices to your network. You define access by selecting or specifying the MAC addresses of the wired and WiFi devices that either can access your entire network or are blocked from accessing your entire network."
Or are you trying to do something else?
Dragonlim
Jul 07, 2017Guide
Yes, it is misleading. Access Control is not available at all ie. have gone through all the menu items available.
Please advise when the next upgrade will be available to turn on this feature.
I use Fiddler to capture the traffic, I manage to get the link to Access Control. But, even I get there, the
Access Control Page is available, but nothing can be done. Fyi.
Thanks.
- michaelkenwardJul 08, 2017Guru - Experienced User
Dragonlim wrote:Please advise when the next upgrade will be available to turn on this feature.
You'll have to ask the official support people.
