Dragonlim
Jul 06, 2017Guide
R6120 Security Menu Missing Access Control
Just bought R6120 yesterday. Want to setup MAC Access Control List, unfortunately cannot find it in Security Menu. Hope that it will be available in the next upgrade. Fya, Thanks !
- Jul 25, 2017
Hi All,
I just upgrade to the new firmware V1.0.0.28.
Good News !
Access Control is available and working fine !
Hope that it helps other with the same issue.
Thanks.
Best regards
Dragon Lim
Dragonlim
Jul 07, 2017Guide
Yes, it is misleading. Access Control is not available at all ie. have gone through all the menu items available.
Please advise when the next upgrade will be available to turn on this feature.
I use Fiddler to capture the traffic, I manage to get the link to Access Control. But, even I get there, the
Access Control Page is available, but nothing can be done. Fyi.
Thanks.
michaelkenward
Jul 08, 2017Guru - Experienced User
Dragonlim wrote:Please advise when the next upgrade will be available to turn on this feature.
You'll have to ask the official support people.
- DragonlimJul 08, 2017Guide
Noted.
Thanks !
- DexterJBJul 10, 2017NETGEAR Moderator
Hi Dragonlim,
Please try going to Advanced > Administration > Attached Devices. There should be a link at the top right for the Access Control Settings.
Dexter
Community Team
- DragonlimJul 10, 2017Guide
Hi DexterJB,
Already tried your suggestion, sorry to say, it isn't there.
Thanks.
Best regards
Dragon Lim
