Sarav
Aug 07, 2016Aspirant
R6220 - Wifi Analytics wont get connected
Hi, The router R6220 has been connected and I was able to access internet. The WIFI Analytics feature placed within Netgear Genie Androd App says its Not Connected and iam not able to use any of...
Sarav
Aug 13, 2016Aspirant
1. What is the firmware version of the router?
R6220 V1.1.0.34
2. What version of NETGEAR Genie do you have installed?
App V2.4.34
3. Do you have it installed on a wireless device?
Yes In Android mobile v 6.0
4. Have you tried using another device (wireless capable computer, smartphone, tablet)?
Tried in another Android mobile v 5.1.
It works well.
5. Are you getting an error message? If yes, what is the error message?
No errors. It says not connected. Though the wifi status is connected and I am able to access internet.
Does this app run on marshmallow Android 6.0?
6. Please provide a screenshot if possible.
