JulienG0677
Sep 03, 2019Aspirant
R6220 not conneting with Nighthawk
Hello, My R6220 used to connect perfectly on Genie App on iOS (latest OS and app versionà. I have upgraded to Nighthawk App and it can not connect: it says: "Logon timed out, please try again. I...
JulienG0677
Sep 04, 2019Aspirant
Yes I have latest version everywhere (router firmware, ios, app)
The access through browser works fine with the IP but I want the mobile app to work.
What else could I explore?
Sep 04, 2019Guru - Experienced User
did you try uninstalling, restarting the phone, and reinstalling the app?
- JulienG0677Sep 04, 2019Aspirant
Yes - multiple times on both my iPhone and iPad.
In the R6220, I see nothing in the logs when I tried to login
- plemansSep 04, 2019Guru - Experienced User
what version of IOS are you using? Device model?
iPhone 8 plus
iPad Pro 10.5
iOS version on both device:12.4.1
