Snorkum's avatar
Snorkum
R6250 Devic Name Change
Does anyone know how I can change the Device Name in Router Model 6250?
It's driving me nuts.
  • schumaku's avatar
    schumaku
    What device name, in which context?
    The only context I have in mind might be the Network/Device Name for USB sharing, defaulting to "readyshare" -> Advanced > USB Storage > Advanced Settings
    The device name (as visible in the Nighthawk App) can't be changed on many older / simpler router models. if oyu have confgured multiple R6250 in the App for example, you need to distingush from the serial number....
    • Snorkum's avatar
      Snorkum
      This is what I mean. When I go into LAN Setup, pic below, I can see the Printer.
      Then when you go into attache devices you don't see the printer. Pic below
      Why does it not display on both?
      • michaelkenward's avatar
        michaelkenward
        It may be some time before the images land. To ensure that you aren't posting anything naughty, a Netgear moderator has to approve the pictures.
        You can attach images to messages without any delay.
    michaelkenward
    Hard to tell what you are talking about with so little information to go on.
    That you have posted in the apps section rather than the one for your R6250, suggests that you may be talking about the names that show up in the Device Manager.
    Are you saying that you cannot Edit the names there?
    Or do your edits disappear after the event?
    Some of us find it easier to edit those names either in the browser graphical user interface (GUI) or, easier still, in the desktop genie for tour operating systems.
    Netgear is trying to kill the genie. It has broken some of the key links to it.
    First look on the support pages for your device:
    Support | NETGEAR
    Feed in your model number and check the downloads for your hardware.
    If that fails, the last sighting of the genie that worked was here:
    genie Landing Page | Apps | Discover | Home | NETGEAR
    Maybe you mean something else. If so, a more detailed explanation from you might help.
    • Snorkum's avatar
      Snorkum
      Maybe this will clarify it a little beter. In advanced, when I go to Setup>LAN Setup I see the following:
      Address Reservation
       # IP AddressDevice NameMAC Address
       1192.168.1.3Canon Printer MG2900F8:0D:60:1A:71:52
      When I go to Administration, or in basic, Attached Device I see the following:
      Wireless Devices (Wireless intruders also show up here)
      #IP AddressDevice Name MAC Address
      1192.168.1.3           --F8:0D:60:1A:71:52
      Same IP and MAC address, but one shows the Device Name the other don't. Why?
      Can I change this somehow?
        michaelkenward
        See above.
        Tried those suggestions?
