PCr78
Mar 18, 2022Aspirant
R6250 Unable to manage Guest Wifi by using Nighthawk
Hi, I used to turn on or turn off Guest Wifi (2,4 GHz or 5,2 GHz) on my R6250 routeur by using Nigthawk app but for more than a week it dosn’t work. I have restarted my router and the mobile app but...
michaelkenward
Mar 19, 2022Guru - Experienced User
What happens when you try? Any prompts or messages?
Can you do this using the graphical user interface (GUI)?
How are you using the app? Local wifi or Anywhere Access?
Android app or iOS?
- indytimMar 19, 2022Aspirant
Same issue for me. The app says, Router not found. I can't access the web interface of the router at 192.168.1.1 after the latest firmware update. I can't connect to port 80 or 443 using netcat; I receive "Connection refused." errors. The firmware update has caused this issue and I can't seem to fix it with a reboot.
- michaelkenwardMar 19, 2022Guru - Experienced User
indytim wrote:
Same issue for me.
Not really. Possibly, not at all.
PCr78 is asking about managing the guest account for wifi. (Look at the subject.) You don't mention that.
The app says, Router not found. I can't access the web interface of the router at 192.168.1.1 after the latest firmware update.I see no sign that this is what PCr78 sees. (It is bad form, and against the rules, to hijack someone else's conversation.) Oh, and "the latest firmware update" tells us nothing about which version you actually installed. There are various ways of getting "the latest".
But, even though there may be very few similarities in your issues, let's persist, with apologies to PCr78.
Which app? iOS? Android?
Which browser for the web interface? Tried another one?
Does routerlogin.net work?
The firmware update has caused this issue and I can't seem to fix it with a reboot.How about a reset and then reboot? (Save the settings, if you can, before doing that.)
Roll back to the previous firmware to confirm that this really is the issue.
Finally, which modem/gateway delivers the Internet to your router?
You again. Oh, okay. I'll just resolve this on my own.
- PCr78Mar 20, 2022AspirantHi,
Here is my configuration :
Firmware router R62500 version v1.0.4.38
Nighthawk app iOS version 2.15.0.214.
By using the Nighthawk app on my iPhone (iOS 15.4) connected to the wifi or LTE I can access to the router and see all devices connected but I can’t switch on or switch off guest wifi like I did previously.- michaelkenwardMar 20, 2022Guru - Experienced User
Thanks for the extra details.
Did you see if you can turn the quest on/off through the graphical user interface (GUI)?
That would help to narrow the problem down to the app or to the router's firmware.
As I said, it works here with my Android app.
Hi,
I confirm I can switch guest wifi on/off by using Chrome webbrowser connected to the Wifi.
But I can't by using the Nighthawk iOS App connected to the Wifi.
It's very surprising because I've been using Nighthawk for turning on/off Guest wifi for more than a year.
It's very useful for managing kids internet connexion.
