PCr78
Mar 18, 2022Aspirant
R6250 Unable to manage Guest Wifi by using Nighthawk
Hi, I used to turn on or turn off Guest Wifi (2,4 GHz or 5,2 GHz) on my R6250 routeur by using Nigthawk app but for more than a week it dosn’t work. I have restarted my router and the mobile app but...
michaelkenward
Mar 19, 2022Guru - Experienced User
What happens when you try? Any prompts or messages?
Can you do this using the graphical user interface (GUI)?
How are you using the app? Local wifi or Anywhere Access?
Android app or iOS?
indytim
Mar 19, 2022Aspirant
Same issue for me. The app says, Router not found. I can't access the web interface of the router at 192.168.1.1 after the latest firmware update. I can't connect to port 80 or 443 using netcat; I receive "Connection refused." errors. The firmware update has caused this issue and I can't seem to fix it with a reboot.
