Rwmt
Jun 11, 2017Guide
R6300v2 Firmware Update Fail
Trying to update my R6300v2 Router firmware so I can use ipv6. When I try to upload it says the firmware is not correct . Please help!
William10a
Jun 11, 2017Master
Is there a v2 after the model on the bottom label with the model number on it?
Version 2 firmware should be 1.0.4.8 for the R6300v2 and version 1 should be 1.0.2.80 for the R6300.
What firmware did you try update too ?
