Rwmt
Jun 11, 2017Guide
R6300v2 Firmware Update Fail
Trying to update my R6300v2 Router firmware so I can use ipv6. When I try to upload it says the firmware is not correct . Please help!
Rwmt
Jun 12, 2017Guide
I don't have a desktop or laptop :(
Will it work with a snartphone or a tablet?
- William10aJun 12, 2017Master
The problem with updating the firmware via wifi if you lose the wifi connection during the process the router could be bricked but the router should auto update the firmware when you log into the router.
https://www.netgear.com/support/product/R6300v2.aspx#download
Page 15 tells about the firmware update process.
