Rwmt
Jun 11, 2017Guide
R6300v2 Firmware Update Fail
Trying to update my R6300v2 Router firmware so I can use ipv6. When I try to upload it says the firmware is not correct . Please help!
Rwmt
Jun 19, 2017Guide
Why does the firmware version my router is currently using (V1.0.3.6_1.0.63CH) not appear in the list of older firmware versions for R6300V2 routers? And why does it say there are no new firmware versions available when I use the Internet search on routerlogin.com? I have attempted to update to all firmware versions above V1.0.3.6_1.0.63CH and all of them have said they are incorrect for this router (R6300V2) How can this be? What can I do to get this router firmware up to date so I can begin operating on ipv6?
William10a
Jun 19, 2017Master
You can download the firmware from this link https://www.netgear.com/support/product/R6300v2.aspx#Firmware Version 1.0.4.8
You can manually update the firmware via the download from Netgear the version of the firmware may be the version that it shipped with.
When offers to options to update from the web or manual use manual and select the location that you saved the new firmware too on your computer via a wired lan cable.
