D_67
Jan 13, 2024Aspirant
R6400 changed the SSID and now app indicates router unreachable.
Having trouble with nighthawk app on android mobile. It was up and running fine. I changed the SSID on router and now the app is indicating the following message "Your router is unreachable. Please c...
michaelkenward
Jan 13, 2024Guru - Experienced User
D_67 wrote:
I changed the SSID on router and now the app is indicating the following message "Your router is unreachable. Please check that your router is on. If this issue persists, try rebooting your device."
A few thoughts.
Did you tell the phone to forget its old connection to the router?
Was it just the SSID that you changed? Same password?
At what stage does the message appear?
I this a local connection to the router, or remote (Anywhere access?
Connecting the app to the router goes through several stages:
- Connect the mobile to the router's wifi
- Login to the Anywhere Access cloud account
- Login to the router's "admin" credentials
What firmware version do you have on the router?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
- D_67Jan 14, 2024Aspirant
I didn't tell the phone to forget the original connection, but I have now tried that and it is still not working. I have also tried changing the MAC and turning off randomization and that didn't work.
I have R6400v2
Firmware version v1.0.4.128_10.0.104
It is happening at the stage when I am logging into router's 'admin' credentials.
I believe this would be considered a local connection.
The modem is not a router. I have used the app on the phone with no problem prior to changing both the SSID and password.
Any help is appreciated.
- michaelkenwardJan 14, 2024Guru - Experienced User
You will get that question regardless of the connection, local or cloud.
You do have to set up the link to Anywhere Access with a local wifi connection. Only then will you be able to get in from a remote Internet sessionvia Netgear's cloud.
The modem is not a router. I have used the app on the phone with no problem prior to changing both the SSID and password.I have lost count of how many people make that claim only to be proved wrong. Don't expect informed responses if you don't want to name the modem.
You may be correct. We just need to rule out other possibilities.
- D_67Jan 14, 2024AspirantArris tm3402
