victorbond
Mar 13, 2022Tutor
r6400v2 can't access router using app
I am having difficulty accessing my router. I can access it via the web but not with my iPhone. I haven't had problems with it until recently. It says that the device if offline but, it is not. Or I ...
Mar 13, 2022Guru - Experienced User
do you have random mac/private IP address turned on on the iphone?
Does it work on an android phone?
victorbond
Mar 13, 2022Tutor
I did not know that was a thing. I've had the phone for 2 years and the problem has just started in the last few weeks. I'm assuming the suggestion will be to turn that off and see if that fixes the issue?
I do not have an android device to try and see if that would work.
It seem like the issue coincided with the most recent Apple update. I don't know if that's coincidence or if there's more to that.
