PJD1978
Mar 26, 2023Tutor
R6700v3 - can't connect via Nighthawk App
I have an R6700v3 router behind a spectrum E31T2V1 modem. Router firmware is V1.0.4.128_10.0.104. I can connect through web access into router, but every time I try to connect throb Nighthawk App, ...
michaelkenward
Mar 27, 2023Guru - Experienced User
PJD1978 wrote:
I can connect through web access into router, but every time I try to connect throb Nighthawk App, I get an error saying "Router is unreachable."
Which app? iOS? Android?
Is the mobile device connected to the WiFi from the R6700v3?
You need to do that before you get to the bit where you enter the admin password.
PJD1978
Mar 27, 2023Tutor
As I said in the post, it is both android and iPhone that cannot connect.
Of course I'm on the wifi network with each device "before" attempting to log in.
Android gives the error "router is unreachable" and iPhone says "logon timed out"
Is there a setting or something in the router to allow/ disallow app access?? I can connect directly to router through both phones and laptop using routerlogin.net or directly typing the IP 192.168.1.1
