PJD1978
Mar 26, 2023Tutor
R6700v3 - can't connect via Nighthawk App
I have an R6700v3 router behind a spectrum E31T2V1 modem. Router firmware is V1.0.4.128_10.0.104. I can connect through web access into router, but every time I try to connect throb Nighthawk App, ...
PJD1978
Mar 27, 2023Tutor
As I said in the post, it is both android and iPhone that cannot connect.
Of course I'm on the wifi network with each device "before" attempting to log in.
Android gives the error "router is unreachable" and iPhone says "logon timed out"
Is there a setting or something in the router to allow/ disallow app access?? I can connect directly to router through both phones and laptop using routerlogin.net or directly typing the IP 192.168.1.1
rcb2022
Mar 27, 2023Aspirant
I have the same problem, perhaps worse.
I have the Nighthawk app set up on my phone. The router works, my devices have access, everything seems fine.
However, I have an older printer/scanner that I had wirelessly attached to my old router. I have been trying to connect it to the new Nighthawk AC3200.
It won't connect through the HP setup. It tells me that MAC address filtering may be preventing the connection. MAY be preventing it. I need to go into the router app and fix it.
I try to connect to the Nighthawk app. When I first set up the Nighthawk app on my phone, I configured it to accept my fingerprint through the phones finger print reader. When I launch the app it shows me the various aspects of the app- device manager security, etc. However, it then bounces me to login as admin. I do the fingerprint, which it recognizes and accepts, but then it again asks me to login as admin with a password. I do not think I changed the default from "password," but just set up the fingerprint. Now, I cannot log into the app after it accepts the fingerprint. If I put in other passwords, it says wrong. If I put in the default password it says "router is unreachable."
Routerlogin.net and routerlogin.com appear to be broken. The links on those pages seem to be circular redirects, and going directly to the router's IP address just brings up another login page.
I think my only option is to find a time when no one in my family is working from home or using the internet, doing a hard reboot, and reconnecting everything.
I have never dealt with anything as opaque and difficult to work with as the Nighthawk app, and I don't think I will ever buy another netgear product, a brand I used to revere. The utter lack of customer support is dispiriting. Turfing things off to "the community" is no substitute for actual support.
