PJD1978
Mar 26, 2023Tutor
R6700v3 - can't connect via Nighthawk App
I have an R6700v3 router behind a spectrum E31T2V1 modem. Router firmware is V1.0.4.128_10.0.104. I can connect through web access into router, but every time I try to connect throb Nighthawk App, ...
rcb2022
Mar 27, 2023Aspirant
Same problem with the router being unreachable.
I'm pretty sure the problem connecting the printer/scanner to my network is due to MAC address filtering on the router, but I can't get into the app to change that setting because the app says the router is unreachable.
michaelkenward
Mar 28, 2023Guru - Experienced User
It would be interesting to know how you reached that conclusion.
If you are right, this would add a brand new issue to the portfolio of problems that people report here.
But it is hard to tell what is going on from your complicated description, which includes a load of stuff about fingerprints that has not much to do with getting a router to work.
- rcb2022Mar 28, 2023Aspirant
- michaelkenwardMar 28, 2023Guru - Experienced User
Doesn't add much. Heaven only knows what that screen comes from. Not the router.
The Nighthawk App mentioned in the subject has nothing to do with establishing a WiFi link to the printer.
Did you find this?
Installing HP wireless printer software | Wireless Printing Center | HP® United Kingdom
Is your router still in its "out of the box" state? That WiFi SSID suggests so. Nothing wrong with that.Just a clue as to what is happening at your end.
TL, DR: I have the same problem using the Nighthawk app as the other user: it returns a message saying the router is unreachable when I try to log in.
The overlong version: A little over a year ago, I bought a R8000-100NAR Nighthawk X6 AC3200 router to replace a Norton Core router that Norton discontinued/bricked. I was never able to get my older HP printer/scanner to connect to the new router, although it worked fine with the Norton Core. A few days ago, I picked the printer up and carried it to the room where my computer is. I connected it with a cable and went through set-up with the HP printer set-up utility on my computer. It failed, returning a report that it was probably due to MAC address filtering.
However, when I tried to check the MAC settings on the router, I was unable to login. When I set up the Nighthawk app, I set it up to log me in my reading my fingerprint. However, after reading my fingerprint, it asks me to log in with a password. After many failed attempts, I finally guessed the password I had used, only to have the app tell me that it can't run because my router is unreachable. The router runs fine, everyone connects happily, but I cannot add this device to my network because I can no longer open the app to check and change settings.
i looked at the HP link posted, but for me it opens here https://www.hp.com/gb-en/shop/list.aspx?fc_conn_wifi=1&sel=PRN. Possibly because I am not in the UK. It's really not a problem doing set-up, as it worked on the Norton Core, it's a problem with a default setting on the nighthawk router. Possibly an "out of the box" problem, if that term refers to using a device with its default configuration. Unfortunately, I can no long get into the router to change anything.
