PJD1978
Mar 26, 2023Tutor
R6700v3 - can't connect via Nighthawk App
I have an R6700v3 router behind a spectrum E31T2V1 modem. Router firmware is V1.0.4.128_10.0.104. I can connect through web access into router, but every time I try to connect throb Nighthawk App, ...
rcb2022
Mar 29, 2023Aspirant
TL, DR: I have the same problem using the Nighthawk app as the other user: it returns a message saying the router is unreachable when I try to log in.
The overlong version: A little over a year ago, I bought a R8000-100NAR Nighthawk X6 AC3200 router to replace a Norton Core router that Norton discontinued/bricked. I was never able to get my older HP printer/scanner to connect to the new router, although it worked fine with the Norton Core. A few days ago, I picked the printer up and carried it to the room where my computer is. I connected it with a cable and went through set-up with the HP printer set-up utility on my computer. It failed, returning a report that it was probably due to MAC address filtering.
However, when I tried to check the MAC settings on the router, I was unable to login. When I set up the Nighthawk app, I set it up to log me in my reading my fingerprint. However, after reading my fingerprint, it asks me to log in with a password. After many failed attempts, I finally guessed the password I had used, only to have the app tell me that it can't run because my router is unreachable. The router runs fine, everyone connects happily, but I cannot add this device to my network because I can no longer open the app to check and change settings.
i looked at the HP link posted, but for me it opens here https://www.hp.com/gb-en/shop/list.aspx?fc_conn_wifi=1&sel=PRN. Possibly because I am not in the UK. It's really not a problem doing set-up, as it worked on the Norton Core, it's a problem with a default setting on the nighthawk router. Possibly an "out of the box" problem, if that term refers to using a device with its default configuration. Unfortunately, I can no long get into the router to change anything.
michaelkenward
Mar 29, 2023Guru - Experienced User
This just rehashes things said before. I repeat, this is almost certainly not the same problem as PJD1978 .
Solving it requiring troubleshooting rather than going in with a preconceived idea on mac addresses about what is a going wrong .
How to Connect Your Printer to WiFi | HP® Tech Takes
Piling in on this conversation does the original poster a disservice and is against the rules of this community.
NETGEAR Community Terms Of Service | Answer | NETGEAR Support
- Behave with civility and mutual respect. Flaming or name calling will not be tolerated. Similarly, any message containing the following will be removed at the discretion of either a Community moderator or administrator:
- Off-Topic posting
- Thread hi-jacking
