drwnhunter
Aug 18, 2022Tutor
R6700v3 - The Netgear NightHawk App Firmware Cannot Be Updated At This Moment
How come this firmware version V1.0.4.106 cannot be updated at this moment? Please help and thank you very much all in advance!
- Aug 18, 2022
What FW version is currently loaded on the router?
Are you downloading the FW files to your PC and using a web browser to send th FW file to the router?
What model router do you have?
Use MS Edge, Firefox or Opera
Aug 18, 2022Guru - Experienced User
You might try updating the Fw manually instead using a web browser and PC. Actually is preferred using this method.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
drwnhunter
Aug 18, 2022Tutor
Hello. Thanks. But I tried doing that method and it keeps showing me that notification from the screenshot as well.
- FURRYe38Aug 18, 2022Guru - Experienced User
Use MS Edge, Firefox or Opera- drwnhunterAug 18, 2022Tutor
I am just using the Netgear NightHawk App from my iPad mini 5 iOS operating system.
