Booyah12
Jan 30, 2020Aspirant
R6700v3 disable airtime fairness
I'm trying to disable airtime fairness on my r6700v3. Sonos stopped working, and that was their suggestion to fix it. I cant for the life of me find this setting in the nighthawk app. Sounds like it m...
- Jan 31, 2020
Booyah12 wrote:
I'm trying to disable airtime fairness on my r6700v3.Get a copy of the manual and read the section Airtime Fairness.
It seems that the V3 manual leaves out that bit. (Typical Netgear.) So get the V1 manual. It maybe that they removed that feature from V3, but the data sheet still touts it. Go figure.
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find all the documentation for your hardware.
Booyah12 wrote:
I cant for the life of me find this setting in the nighthawk app. Sounds like it may have been a setting in the old now-unsupported genie app.Yet another feature that they broke in this "updated" app.
michaelkenward
Jan 31, 2020Guru - Experienced User
Support | NETGEAR
Booyah12
Feb 01, 2020Aspirant
That worked! Thanks so much for your help!
